Can someone help me. Trying to get the height parameter. The height value is incorrect in the Element.GetParameterValueByName. I’m using Dynamo 0.9.2.4472
Hi Meng,
Currently values which your getting is in ft you need to convert to mm. You can multiple your values by 304.8 or you can use custom node from Lunchbox package. Good Luck!
thanks KULKUL I will be using the lunch box from now on
