Output in the 'IF' node
That is because Scope-If is originally meant for use inside custom nodes. Scope-if (unlike any other dynamo nodes) works by only running the test-value and not anything else. Thus if you have more than one node before either “true” or “false” input you run the risk of Dynamo halting.
Are you yourself using 1.3.x or 2.0?
