Order Elevations in a room clockwise by points
Hi there, I have this room that isn’t exactly normal in shape as well as rooms that are basic and square shaped. I’m trying to order these elevations/points in a list so that they start from the top left and move around clock wise. Any ideas?
So it’s actually quite difficult… at least as far a I found in my testing.
Assuming all markers have one elevation only you could do it like attached. It probably isn’t a one size fits all approach, but worked well for me in testing. Detecting clockwise tends to be a challenge so I added a boolean that the user can nominate to reverse, as well as which marker to begin from.
elevation order by boundary.dyn (35.4 KB)
Thank you for the help! it works however there was an issue with the python script getting the x y z coordinates but i just wrote a python scrip that gets the boundingbox max and min of the elevation marker and average it out.
Yes sometimes if a point is at a Z height I just pull it down by getting its X/Y values and using the XY point construction node. Curves can be pulled to a common plane using the pull to plane node.
