Hi, I installed orchid but now its giving multiple definitions in python into some nodes and messing up scripts. This one is clockworks character.fromnumber. Is there a way to resolve this?
The main way to resolve this is to rename the code in the codeblock (that isn’t python) to the full qualified namespace.
So in your case, Math.Floor((n-1)/26)
would become DSCore.Math.Floor((n-1)/26)
but I did think this was fixed previously so it is a bit odd for it too show back up.
for further help, you are going to have to ask the Orchid package author as he can make changes to remedy this for end-users (FYI, he most likely will not.).
The last time I mentioned anything about this package this is what happened to me.
I’m not sure this will work, but in the .dyn there is also an entry called namespace resolver, it should map short name spaces to full ones… if you have tons of namespaces to remap you might try editing that entry as an experiment…
backup your graph first
You can always do a find and replace as well in a text editor.
