Opening Edge to Wall Edge distance
Is it possible to only get the distance from the opening edge to wall edge and opening edge to opening edge?
Opening Edge to Wall Edge distance .dyn (28.9 KB)
Yes - if you want to get the layout as you have illustrated then look into the dimensioning workflows.
If you just want to do a geometric analysis then Instead of using element.children and bounding boxes I recommend you use the geometry of the wall.
  1. The Revit API has some methods to get the inside or outside face of a wall, which you can then convert to Dynamo geometry.
  2. Edges can then be filtered by the Z component of their direction - anything primarily vertical will need a measurement for your horizontal distance study.
  3. Sort the lines by their relative parameter along the walls’s location curve to assure lines are ordered from wall start to wall end.
  4. For each line excepting the final line:
    1. Get the nearest point on the line to the next line.
    2. Get the nearest point on the next line to the line.
    3. Build a vector between the two points.
    4. Extract the XY component and get the length - this is the horizontal distance between the components.
    5. Write out the horizontal distances.
Note that you might want to group stuff by inclusion in a common vertical range between step 3 and 4. I won’t go into the logic for that as those steps won’t help if you don’t manage the base steps first.
Give it a shot and see where you get.
Hi @jacob.small, the distance is resulting 0. I’m not sure what I’m doing wrong.
Opening Edge to Wall Edge distance .dyn (37.6 KB)
Look at how many items you have at each step. For a basic wall there are at least four surfaces which have a normal with a z component of 0 - the front face, the back face, the left side, and the right side.
You need to get either the front or back face.
As a side note, you appear to be using an antique for all of this work. Revit 2022 isn’t supported, and you’re going to be spending a LOT of time maintaining the antique and the supported builds. Time to update.
Hi
a solution using a horizontal line scan to find intersections with the vertical lines of a surface
Python code with Revit 2026 ( needs to be adapted for earlier versions.)
import sys
import System
#import net library
from System import Array
from System.Collections.Generic import List, IList, Dictionary, HashSet
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
wall = UnwrapElement(IN[0])
debug = []
lines_between_opening = []
wall_int_ref = DB.HostObjectUtils.GetSideFaces(wall, ShellLayerType.Interior)[0]
face_int = wall.GetGeometryObjectFromReference(wall_int_ref)
all_vertical_curves = [curv for loop in face_int.GetEdgesAsCurveLoops() for curv in loop if abs(curv.ComputeDerivatives(0.5, True).BasisX.Z) > 0.9]
ds_face_int = face_int.ToProtoType()
# get top edge
align_ds_bbx = BoundingBox.ByMinimumVolume(ds_face_int)
ds_top_pt1 = DS.Point.ByCoordinates(align_ds_bbx.MinPoint.X, align_ds_bbx.MinPoint.Y, align_ds_bbx.MaxPoint.Z)
ds_top_pt2 = align_ds_bbx.MaxPoint
ds_top_line = DS.Line.ByStartPointEndPoint(ds_top_pt1, ds_top_pt2)
top_line = ds_top_line.ToRevitType()
# get min Z
minZ = align_ds_bbx.MinPoint.ToXyz().Z
i = 0
current = top_line
offset = 0.2
while (current.GetEndPoint(0).Z - offset) > minZ and i < 10000:
    i += 1
    current = current.CreateOffset(offset, XYZ.BasisX)
    # search all intersection with vertical curves
    temp = []
    for curv in all_vertical_curves:
        intersectResult = current.Intersect(curv, CurveIntersectResultOption.Detailed)
        if intersectResult.Result == SetComparisonResult.Overlap:
            for overlap_pt in intersectResult.GetOverlaps() :
                temp.append([overlap_pt.FirstParameter , overlap_pt.Point.ToPoint()])
    # sort points by parameter
    temp.sort(key = lambda x : x[0])
    if len(temp) > 2:
        # iterate through the points two at a time.
        iter_intersect = iter(temp)
        for (para1, pt1), (para2, pt2) in zip(iter_intersect, iter_intersect):
            lines_between_opening.append(DS.Line.ByStartPointEndPoint(pt1, pt2))
OUT = lines_between_opening
Hi @c.poupin, Thank you for sending this. I’ve tested the script and it is resulting in a empty list. I’ve attached the Revit model for your review.
Opening Edge to Wall Edge distance_detached.rvt (2.6 MB)
hi, here is the fixed code
import sys
import System
#import net library
#import Revit API
debug = []
# get top edge
#debug.append(ds_top_line)
#debug.append(ds_face_int)
# get min Z
i = 0
current = top_line
offset = -0.2
direction = top_line.Direction.CrossProduct( XYZ.BasisZ).Negate()
while (current.GetEndPoint(0).Z - offset) > minZ and i < 1000:
    i += 1
    current = current.CreateOffset(offset, direction)
    debug.append(current.ToProtoType())
    temp = []
    if len(temp) > 2:
        # iter 2 by 2 on intersection points
Hi, @jacob.small, its giving the wrong horizontal distances between the components. Is there a way to find the distance between the edges only? I’ve attached the screenshots below.
Opening Edge to Wall Edge distance WIP .dyn (70.5 KB)
Missing step 3 in the proses I outlined above by the looks of it. The list.SortByKey node appears to have the wrong key.
Thank you @jacob.small, Is there a way to separate the list - one for Opening Edge to Opening Edge and one for Opening Edge to Wall Edge?
Wall edges would be closed to parameter 1 and parameter 0 of the location curve.
@jacob.small, I’m trying to get the distance of a opening stacked on top of each other but the script is not working. Is it to do with the List.Levels?
Opening Edge to Wall Edge distance stacked.dyn (105.8 KB)
Hard to say. Do you have a supported Revit model (2023 or newer, soon to be 2024 or newer) for a dataset?
@jacob.small Yes, Revit 2025 model attached
Opening Edge to Wall Edge distance stacked R25.rvt (2.8 MB)
@jacob.small Script attached.
Opening Edge to Wall Edge distance.dyn (109.8 KB)
I am noodling over a POC package for identifying the isocurves needed for getting the dimensions you are after. It won’t place dims, but it’ll sort place the curves into groups and sort them from start to end and show you where the curve across teh face should be placed. Will target Dynamo 2.16 though so you may not be able to use it in older builds (no one would be doing any work in those anyway).
However, I am out sick today (breakfast didn’t settle) so development isn’t happening at the moment. This GIF from yesterday’s play will have to suffice until I’m back at my desk.
2026_03_31 - horizontal clearances
New package on the package manager - TorsionEngine. Only one node for now - give it a shot. If you need to understand how to use it check the help docs (right click the node, help); there should be a sample you can insert there.
