Obtain Element After Using a Boolean Filter
After I filtered the elements of a category using a certain parameter name, I have used element.byID to obtain the element and to use it to get other parameters. As you can see from the attached screenshot, I am unable to do so. Which node should I use to transform a list of ID’s to elements?
Best,
Hasan Furkan
I do not see the usefulness of element ID in your script
Thank you Akli. Now I do not see the usefulness as well.
I don’t think you need the Cross Product lacing either since the lists are the same length.
in a code block
ElementSelectorBy.Id(Id,true)
You can try the following two options:
  1. try Use String.Contains Node and after the FilterByBoolMask delete yout flatten node
  2. If you don’t need the Id Element, you can obtain directly the element with the FilterByBoolMask Node
I hope either of these two options can solve your problem!
