Object.UpdateProperty does not work correctly
I want to set a property on an object created from Dynamo geometry with Object.UpdateProperty, but it is not reflected.
The property set is defined correctly.
AECPSDAUTOATTACH is set to ON.
Opening and closing the property set definition dialog and running Dynamo multiple times works correctly, but I want this to happen on the first run only.
Is this a system requirement or is there another appropriate Dynamo graph?
Hi @hitoshi, this is one run solution. There is no need to set AECPSDAUTOATTACH to ON.
