Hello everybody,
Since yesterday i get this issue from the ImportInstance.LayerNamesInUse node. The previous node “Import DWG” gives out a ‘null’ value to me this explains why the issued node doesn’t work. My question is the following:
The script worked the day before and I haven’t changed anything to the script since then. Sometimes the script works when i close and open Dynamo and Revit, but most times it doesn’t. Is there a solution for this problem?
I’ve seen other people wih this topic but the solutions i found don’t work in my case.
I’m using GeniusLoci and BimmorphNodes in revit 2021.
Thanks in advance
