Hello there! Thanks to @cgartland I managed to renumber sheets with additional numbers after dots. Now I want to keep those sheets which are in single amount (16 and 26 here) without changing, i.e. just 5 and 1 without adding .1 How can i do that? Here’s the text of original script
def increment_names(names):
name_dict = {}
for name in names:
# If name is not used, set name’s counter to 1
if name not in name_dict:
name_dict[name] = 1
# If name is used, increment its counter by 1
name_dict[name] += 1
num = name_dict[name]
yield ‘{}.{}’.format(name, num)
OUT = increment_names(IN[0])
Is this what you’re trying to do?
increment names 3.dyn (5.0 KB)
name_dict = {}
for name in names:
# If name is not used, set name's counter to 1 and yield name
name_dict[name] = 0
yield name
# If name is used, increment its counter by 1 and yield modified name
yield '{}.{}'.format(name, num)
Well, in this case I’d like it to be
A-101-1.1
A-101-1.2
A-102-1.1
A-102-1.2
A-102-1.3
S-101-1
S-101-2
S-102-1
By the way, how do I insert code like you do that?
Insert the code as preformatted text:
To achieve your above case, you would have to change the structure of the function. You would have to iterate the entire list of names first in order to determine which names only occur once (e.g. S-101-1). If a name occurs more than once, output each name, modified sequentially (A-101-1.1, A-101-1.2…)
Using @cgartland’s code as a base, this should work:
name_dict = {}
for name in names:
if names.count(name) > 1 and name not in name_dict:
name_dict[name] = 1
yield '{}.{}'.format(name, name_dict[name])
elif names.count(name) > 1:
yield name
Edit: A more compressed version, should still work
name_dict = {name : 0 for name in names if names.count(name) > 1}
for name in names:
if name in name_dict:
yield name
