NUMBERING POINTS
Good morning;
I’m new to Dynamo, and
I have generated a list of points, which I want in revit,
put me a text note, numbered in sequence
1… until 11
Could someone help me identify the nodes that I should use.
hello,
in which enviroment are you?
Design study?
You are using adaptive points?
Or just Dynamo points ?
KR
Andreas
Thanks;
I’m using dynamo points;
What I want is to make a form in revit
that in each vertex (points) I put a number from 1 to the end.
for that i used 0..n n is your end-variable which is determined by Count(x) your points @luis.leandro.caldero
