Hi all!
Does anyone know a way to get the normal to a triangulation surface at a point?
As far as I understand, the node in the picture works with a different type of surface
the TIN geometry must be converted to Dynamo geometry first. I did not find direct solution, but here is one.
SurfaceNormalAtPoint.DYN (24.6 KB)
Merci!!
This bit of Python will get the normal without having to do any geometry conversion, and returns the surface directly:
tinSrf = IN[0].InternalDBObject
dynPnt = IN[1]
tri = tinSrf.FindTriangleAtXY (dynPnt.X,dynPnt.Y)
xyzSet = [tri.Vertex1.Location, tri.Vertex2.Location,tri.Vertex3.Location]
pnts = [Point.ByCoordinates(i.X,i.Y,i.Z) for i in xyzSet]
srf = Surface.ByPatch(Polygon.ByPoints(pnts))
norm = Surface.NormalAtParameter(srf,0.5,0.5)
OUT = norm, srf
