SetDifference node
Wrong answer … 3 points
Right answer … 1 point
Help ?
Thanks Robert2017 for the reply
The problem is that my points derive from calculation
They are not the same because there is tolerance … the difference node does not see the same
That is, the node does not work
I had already found this problem
solved in
I had forgotten the solution
