So, i’ve been following the sample on this repository:
Speciffically the sample on the UISliderBound.cs class.
The error message i get is: Dereferencing a non pointer. I know that the most common cause for this error is that the function that the node executes is in the same assembly as the nodeModel Class.
But i can guarantee that this is not the case, and even though the function is in a separate assembly, i keep getting the same error.
Does anyone have any tip?
Thank you!
Edit: I’m using Revit 2020, and dynamo 2.3. The version of DynamoVisualProgramming.WpfUILibrary is 2.0.4.11375
