I’d temper that by stating “without some effort wiring some degree of planning input control to each branch of the graph.”
This node definitely works better with custom nodes than in most graphs.
This is only partially true…
A custom node with content grouped inside of it will not process much of anything if you properly wire a Boolean to control the run state. Most libraries are chalk full of this type of control.
