Hello, is there a trick to determine the index of a redundant item in a list
Cordially
christian.stan
what happened when you groupbyfunction? using Object.identifier
next challenge, use node to code, try to understand it, and write your next script in Designscript.
If you can, contact Håvard Vasshaug
Good evening,
All advice and support is welcome, thank you for motivating me. ![]()
Trying is not giving up.
Cordially
christian.stan
You can do it.
