Hi …
I took a huge chance here.
Autodesk exposed DS Projects, DS and DREF in the API from C3D 2021. I missed that somehow. Only error in the code is creating the Alignment DREFS. Error - no suitable data shortcut found in current project.
Thx for your patience and thx for sharing…
K.
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('AeccDataShortcutMgd')
from Autodesk.Civil.DataShortcuts import *
with adoc.LockDocument():
vals = DataShortcuts.CreateDataShortcutManager(True)
dsm = vals[0]
c = dsm.GetPublishedItemsCount()
o = []
for i in range(c):
p = dsm.GetPublishedItemAt(i)
if not p.IsBroken and p.DSEntityType == 1:
o.append([p.Name , p.DSEntityType])
DataShortcuts.CreateReference(adoc.Database,p.SourceFileName, p.Name, DataShortcutEntityType.Alignment)
OUT = o
