Good day!
I have an input list - no.1 which will be turn out to output list - no.2. And i want to achieve that result by using Imperative block. i try with t0 and it work, but no chance for t1 which is a nested while loop in a for loop.
Could you help me to figure it out?
Any help will be appriciated!
Thank you!
Hi @Nicolas.B
here you are trying to itterate through a number and not a list (an array). You need to adjust slightly the first loop like this.
for (i in 0..count1 - 1)
I also don’t fully understand why using this to put everything into an additonal list when you have already a list with everything you need after execution.
t2 = List.AddItemToEnd(tem_t2, t2);
and delete this to avoid quiting the loop after the first itteration
return t1;
