I want to use passthrough to delay an archi-lab node BK.GetAllViews from starting until previous operation is done but it doesn’t have any inputs to make that happen. Could you help me modify it’s code to start operation only after it receives “TRUE” Boolean input?
Here is the setup:
The input wasn’t there originally, I added it:
But right now the input doesn’t do anything because I haven’t modified the code.
Here’s the code, could someone help me modify it to only run after receiving that “TRUE” input?
Code:
#Copyright(c) 2015, Konrad Sobon
# @arch_laboratory, http://archi-lab.net
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
#collect all views in the model
collector = FilteredElementCollector(doc)
views = collector.OfClass(View).ToElements()
#sort views into separate lists based on view type
areaPlans, ceilingPlans, columnSchedules = [], [], []
costReport, details, draftingViews = [], [], []
drawingSheets, elevations, engineetingPlans = [], [], []
floorPlans, internal, legends, loadReports = [], [], [], []
panelSchedules, pressureLossReports, renderings = [], [], []
reports, schedules, sections, threeD = [], [], [], []
undefined, walkthrough = [], []
for i in views:
if not i.IsTemplate:
if i.ViewType == ViewType.AreaPlan:
areaPlans.append(i.ToDSType(True))
elif i.ViewType == ViewType.CeilingPlan:
ceilingPlans.append(i.ToDSType(True))
elif i.ViewType == ViewType.ColumnSchedule:
columnSchedules.append(i.ToDSType(True))
elif i.ViewType == ViewType.CostReport:
costReport.append(i.ToDSType(True))
elif i.ViewType == ViewType.Detail:
details.append(i.ToDSType(True))
elif i.ViewType == ViewType.DraftingView:
draftingViews.append(i.ToDSType(True))
elif i.ViewType == ViewType.DrawingSheet:
drawingSheets.append(i.ToDSType(True))
elif i.ViewType == ViewType.Elevation:
elevations.append(i.ToDSType(True))
elif i.ViewType == ViewType.EngineeringPlan:
engineetingPlans.append(i.ToDSType(True))
elif i.ViewType == ViewType.FloorPlan:
floorPlans.append(i.ToDSType(True))
elif i.ViewType == ViewType.Internal:
internal.append(i.ToDSType(True))
elif i.ViewType == ViewType.Legend:
legends.append(i.ToDSType(True))
elif i.ViewType == ViewType.LoadsReport:
loadReports.append(i.ToDSType(True))
elif i.ViewType == ViewType.PanelSchedule:
panelSchedules.append(i.ToDSType(True))
elif i.ViewType == ViewType.PresureLossReport:
pressureLossReports.append(i.ToDSType(True))
elif i.ViewType == ViewType.Rendering:
renderings.append(i.ToDSType(True))
elif i.ViewType == ViewType.Report:
reports.append(i.ToDSType(True))
elif i.ViewType == ViewType.Schedule:
schedules.append(i.ToDSType(True))
elif i.ViewType == ViewType.Section:
sections.append(i.ToDSType(True))
elif i.ViewType == ViewType.ThreeD:
threeD.append(i.ToDSType(True))
elif i.ViewType == ViewType.Undefined:
undefined.append(i.ToDSType(True))
elif i.ViewType == ViewType.Walkthrough:
walkthrough.append(i.ToDSType(True))
continue
#Assign your output to the OUT variable
OUT = areaPlans, ceilingPlans, columnSchedules, costReport, \
details, draftingViews, drawingSheets, elevations, \
engineetingPlans, floorPlans, internal, legends, \
loadReports, panelSchedules, pressureLossReports, \
renderings, reports, schedules, sections, threeD, \
