Does anyone have experience in pyRevit?
I need to create the button and need to add in the shortcut keys.
then button is to hide and unhide the Linked point cloud from the current view.
Any help appreciated.
from pyrevit import script
#Import pyRevit form library
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import Category
app = __revit__.Application
uidoc = __revit__.ActiveUIDocument
doc = uidoc.Document
logger = script.get_logger()
logger.set_quiet_mode()
collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_PointClouds).ToElements()
cat = None
for i in collector:
cat = i.Category
if cat is not None:
t = Transaction(doc,'hide cloud')
t.Start()
doc.ActiveView.HideCategoryTemporary(cat.Id)
t.Commit()
Update
clr.AddReference("RevitAPI")
import System
# Current doc/app/ui
pc = Autodesk.Revit.DB.PointClouds.IPointCloudAccess.GetName
pc1 =Autodesk.Revit.DB.PointCloudInstance.Name
OUT = pc1
You are question with pyrevit ?
yes
I need to add a new button then I can assign a shout cut key.
Thank you…
