N-time loop of a function
im trying to apply a function n-times to a variabel. In the screenshot I build it up with nodes, but just four times. The goal is to loop this function as often as I want to, and have a list with every single (n-times) output. I already tried with the loop-while node, but couldn´t reach it. After some research, appearently it´s only possible to solve this by Design Script, with a loop funcition, is this correct?
I´m already learning the Design Script, I would appreciate some help!
Thanks,
Stef
Welcome to the Dynamo community @stef
Hope the code below satisfies your requirement
imp_2021-12-26_05-17-34
n = 4;
x = 10;
y = 10;
[Imperative]
	z = 0;
	for (i in 1..n)
		x = x + ((y*2-x)/2);
	return x;
````Preformatted text`
Thanks for the welcome and the solution, you helped me a lot! I transformed it a little and defined the block to use it within my script. Line 7 in your script (z=0) is not necessary, right?
Not necessary.
While your adaptation of the code to a function is nice, if you want a list, you could also do something line this.
imp_2021-12-28_12-38-46
n = 4;
x = 10;
y = 10;
z = [];
[Imperative]
	for (i in 0..(n-1))
		z[i] = x + ((y*2-x)/2);
		x = z[i];
	return z;
i think you can also use scan and reduce for this. i’ll update with a snippet when i get to a different computer. They’re interesting concepts that i haven’t been able to implement well beyond arithmetic examples, but they seem like useful/important ones to understand.
