Multipliy all element of list with number
When i do multiply list of element with and value. it will jut to multiplication of only first value of list.
Is there a way i can get all element of list multiply with specific input. …
Thank you,
Hardik
Introduce a Flatten or List.FirstItem node between User Inputs and y
or
Change the lacing on the * node
Still getting only 1 output in result.
@hardik.dhingani123 Should have tried the other suggestions too
Thank you, it works.
Why are you sending the singular 12 through a List.FirstItem node?
i am not sending singular 12. it will be any number which user will select. it is variable. see my script above.
I believe @Vikram_Subbaiah did this to force the lacing - otherwise shortest would only return one number.
By doing so the list structure is altered such that I can leave lacing at Shortest (as @jacob.small has said above )
20180321-3a
