Lists multiplication
Hello
Could you guys please help me with lists multiplication
I have two lists with different lengths. The first list contains two items, and the second one contains only one item. I need to multiply every item of the first list with every item of the second list.
If I use the “multiply” node it only multiplies the only first item of the first list (as it is shown on the image below)
I need the result to be a list with two items. In this case the items should be “3” and “6”
You must change Lacing to : Longest:
Hi!
It works!
Thank you so much. You saved a lot of my time. How can I donate you?
I’m glad it worked! Donations aren’t necessary. We’re here to help each other out. Feel free to ask if you need anything else.
