I haven’t been able to find an elegant (non-Python) solution to this one: how can I turn a series of “Replace” nodes (ReplaceByCondition or String.Replace) into something more compact? Basically I have a list of values (in this case a list of 0s,1s and 2s) and need to replace each value with a specific String (0 becomes “Project Base Point”, 1 becomes “Survey Point” and 2 becomes “Relative”). Three keys is manageable, but I’m looking for a solution that works with longer lists of keys. I tried a solution with IndexOf, but that node only seems to pick up the first occurrence of the value. Thanks for any pointers.
Or one (ok, 2!) code block:
This only works as your indexes map directly to the string list. For more complex data structures, @T_Pover example with dictionaries is a good solution
Beautiful! a[x] - couldn’t ask for anything more compact. Thanks much both.
