I have been doing this for awhile, but now I am unable to reproduce this.
As is, the parameters are correctly assigned to the elements (walls), and i am pretty sure this works for any number of parameters or elements.
HOWEVER, for the life of my children, I cannot get lacing/levels setting so that the SetParameterByName node returns the same data structure as input in Element port… I get this doubled list, by elements, but with sublists for each parameter…
Any attempt at getting the same data structure as output will result in the parameters NOT being assigned properly…
Thank you
regards
