Hi all,
I’m trying to use the Element.SetParameterByName node with the following three lists:
- the first list with the elements (walls in my case), this is a one-dimensional list;
- the list with parameters: each element gets its own list of parameters, so this is a two-dimensional list;
- a list with the values to set: each element also gets its own list of values to set, so this is also a two-dimensional list.
list one (elements):
[0] element 1
[1] element 2
etc.
list two (parameters):
[0] List:
[0] parameter 1
[1] parameter 2
etc.
[1] List:
[0] parameter 1
[1] parameter 2
etc.
etc.
list thee (values):
[0] List:
[0] value 1
[1] value 2
etc.
[1] List:
[0] value 1
[1] value 2
etc.
etc.
The image attached might also clarify. In this image it doesn't look like the parameter names nor values vary, but this will have to be possible. That's why I chose to define those parameter names and values for every element in the first case.
How would I go about setting these parameters to the elements, because the Element.SetParameterByName node doen’t take 3 lists. I’ve tried different lacings, transposing lists, making a for loop in a code block (which I failed at), making a Python script with a for loop (which didn’t work as expected). Can anyone help me with this?
As I said I tried using a for loop in a code block, but it says the variables aren’t yet defined which I don’t understand. An image of this code including the error is attached.
Thanks in advance.
Marc
