Modifying material id for DirectShape/Python
Hi All,
A colleague of mine has imported 3D shapes (Brep as known by Dynamo) and I wish to modify the material on the surface. However, I have no luck in doing so. Hoping someone can help me with this.
ps revit’s paint option is out of the box as there are many elements in different locations.
`import clr
clr.AddReference(‘RevitAPI’)
from Autodesk.Revit.DB import FilteredElementCollector, ElementWorksetFilter, Options, Solid, OverrideGraphicSettings
Input: Workset ID and Material ID
workset_id = IN[0]
material_id = IN[1]
Get the current document
Create a filter for the workset
workset_filter = ElementWorksetFilter(workset_id)
Collect all elements in the workset
elements_in_workset = FilteredElementCollector(doc).WherePasses(workset_filter).WhereElementIsNotElementType().ToElements()
def GetFaces(direct_shape):
“”“Get all faces from a DirectShape element.”“”
faces =
geometry = direct_shape.get_Geometry(Options())
if geometry:
for geom in geometry:
if isinstance(geom, Solid):
for face in geom.Faces:
faces.append(face)
return faces
def SetMaterialOverride(element, material_id):
“”“Set the material override for an element.”“”
ogs = OverrideGraphicSettings()
ogs.SetSurfaceMaterialId(material_id)
doc.ActiveView.SetElementOverrides(element.Id, ogs)
Initialize lists to store DirectShapes and their faces
direct_shapes =
faces_list =
Filter DirectShape elements and get their faces
for element in elements_in_workset:
if element.Name == ‘DirectShape’:
direct_shapes.append(element)
faces_list.append(GetFaces(element))
Set material override for each DirectShape element
for element in direct_shapes:
Output the number of faces
OUT = len(faces_list)
clr.AddReference("RevitAPI")
# Input: Workset ID and Material ID
workset_id = IN[0]
material_id = IN[1]
# Get the current document
# Create a filter for the workset
# Collect all elements in the workset
"""Get all faces from a DirectShape element."""
    faces = []
    if geometry:
                    faces.append(face)
    return faces
"""Set the material override for an element."""
# Initialize lists to store DirectShapes and their faces
direct_shapes = []
faces_list = []
# Filter DirectShape elements and get their faces
    if element.Name == "DirectShape":
# Set material override for each DirectShape element
# Output the number of faces
paste your code via </>
Hi Desmond, welcome to the forum :wave:
Your code is trying to do two things which are not connected - override an elements graphic settings in a view and change the material painted on the geometry faces
Based on your use case painting the faces is probably the best solution. I haven’t tried the code but it might look something like this
from Autodesk.Revit.DB import (
    Options,
    Solid,
    ViewDetailLevel,
    options = Options()
    options.DetailLevel = ViewDetailLevel.Fine
    faces = []
    geometry = direct_shape.get_Geometry(options)
    if geometry:
                    faces.append(face)
    return faces
workset_id = IN[0]
material_id = IN[1]
elements_in_workset = (
    .ToElements()
faces_list = []
        faces = GetFaces(element)
        for face in faces:
            doc.Paint(element.Id, face, material_id)
            faces_list.append(face)
thanks, you are a legend
Hi @desmond679679 and welcome
For your information, here are the forum rules
(How to get help on the Dynamo forums ) and the community guidelines (https://forum.dynamobim.com/faq )
Note
remember to specify if it’s AI-generated code in your next posts (see point 8 )
