Modify Line Style Color
I have found good information on remapping line weights of projection lines for plans, elevations, etc.:
http://dynamobim.org/forums/topic/changing-line-weight/
I have also found good information that involves python to set the Line Style Line Pattern:
But I haven’t really found any custom nodes or a good path the leads to modifying the RGB color of a named Line Style. I have software that can run dynamo scripts (or a series of scripts on workshared enabled files) at night when the Revit files are not being accessed:
http://www.imaginit.com/software/imaginit-utilities-other-products/clarity
The goal is to move the lines over to the correct Line Styles with one script then change the Line Style color of the incorrect Line Style to Red (with a second script) - so it shows up red - - as something to correct. I have attached a general version of the script I use to reassign (map) one line style to another. Simple one, “Thin Lines” to “1 - Solid”. I’m sot sure if I’m going to need to use a hybrid with python in it for the color part I am trying to accomplish.
Line Style Remap - Thin Lines.dyn (15.7 KB)
thanks man, this helped a lot! :heart_eyes:
