Modify blockreference Z value
Hello everyone,
I would like to modify blockreferences Z value, the idea would be to get the value of an attribute called “ALT” and modify the insertion point Z value.
Do you think of an easy way to do this without using object.transform node?
Thanks a lot
Hello bertrand,
you can fillter out your Blockreferences and find the insert points of the blocks, then you can modify the Z value and then Object.Transform.
TRY
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
editor = adoc.Editor
OUT = Point3d(IN[0].X, IN[0].Y, IN[0].Z + IN[1])
