How to insert BlockReference from python
Is there a way to insert a block reference from python? Im able to add attribute tags or set dynamic properties to existing blocks easily, but cant seem to replace the BlockReference.ByCoordinateSystem() block with a line of python code. Anyone have a way?
Thanks in advance!
Bump
@WWentzler here’s a simple example:
clr.AddReference('AutoCADNodes')
from Autodesk.AutoCAD.DynamoNodes import *
sourceBlock = IN[0]
coordinateSystem = IN[1]
layer = IN[2]
OUT = BlockReference.ByCoordinateSystem(sourceBlock, coordinateSystem, layer, Document.Current.ModelSpace)
Python
Huge thank you! I thought it should be this simple, but was missing the import …DynamoNodes … at the top. This makes things much better. Thanks!!
