Modelling a tunnel ring in revit and dynamo using data from excel
hi, i need help modelling a tunnel in revit/dynamo. i’ll try as much as possible to give a summary of the challenge i’m facing.
I’ve been given three documents to this effect
-a dwg file of just one tunnel ring
- an excel file containing (orientation, key position, ring number)
-a rough sketch of the flattened out ring with the position of each ring segment
how do i go about this, can i get a break down of steps involved .
Hi @Okwara2.Anya
These two AU class may help you
thank you @RMohareb, ill go through it.
