Modeling of High Voltage Stranded Conductors Connections
I am an engineer specializing in the design of high voltage substation. I need help developing a script that will enable the automatic generation of connections in the form of bundled cables (adaptive components family) between high voltage equipment. Currently, I have a part of the script ready, which, after indicating the elements, generates a connection between them. The shape of this connection is defined by a NURBS curve.
It is important to me that, for a certain distance along the connecting elements, this curve is tangent to their axis. This reflects the real behavior of the cables, which are quite rigid and have a limited bending radius. Can someone help with the part of the script that would insert an adaptive family based on the generated points from the aforementioned curve? I’ve tried to do this with adaptive.componentsbypoint node but it doesnt work for me.
Here are attached files WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free
I will be greatful for any help.
Hi Rafal,
I am looking for the same answer. The WeTransfer is not accessible anymore, so I cannot look into your code. What I am doing is looking at the loads on the cable to get a quite realistic shape. I think this is possible in SCIA. I am trying to model a cable, but I am still stuck with the part at the clamps: it follows a catenary curve, but it should be straight for a few cm at the clamp.
