Hi everyone, i’m new on python and im trying to use the dynamo “mirror” inside a python script but it doesn’t work.
i imported ‘Protogeometry’ with relative “Autodesk.DesignScript.Geometry” but nothing.
where am i getting wrong?
thanks!
PS: the pic it’s just an example i did to explain the post
First of all, you are already importing geometry from autodesk designscript, so no need to rewrite those in full later. I see you are importing revit api, so to avoid type clashing, what I tend to do is use the as
keyword after importing protogeometry like this…
from Autodesk.DesignScript import Geometry as geom
And then you can just call geom.Plane.ByThreePoints(... )
As for mirror, this is under Geometry, so you need another Geometry. So, geom.Geometry.Mirror(...)
Hope this helps.
Cheers,
Dan
oh yes it’s working!! thanks!
Awesome! Glad to help! And I forgot to say welcome to the forum (as it’s your first post and all)! So welcome to the forum!
Also, don’t forget to mark this as solved with the little checkbox so other people don’t come rushing to help and people with a similar problem know which post was the solution.
