Hello Dynamo Wizards,
I have been trying to find a way to take overlapping lines and create new lines at overlapping points. I have a list of lines from line loads i have populated that i would like to run through and create new lines at any place the lines overlap a larger line length from the list. Ultimately, this process would allow me to merge the overlapping loads into one load instead of clicking through overlapping loads.Can anyone point me in a direction to do that?
Hi @dweber12 do you have a file you could share with that ?
@NIRMAL Hello. I am not looking for intersecting points but lines that are overlapping in same plane. For example in this image you can see a bunch of overlapping nodes from line loads.
Hard to tell but i highlighted a line load which runs along a length of wall. On top of that are several smaller portions of different loadings which i ultimately would like to merge and create new loadings.
Here are two options which i have tried so far. The loadings aren’t as important right now. I am mainly concerned at the moment on how to take a list of lines and find overlapping lines, create new lines at all intersection points.
