Hi All,
I have an interesting problem.
I need to create a single, large excel file which will include around 10 schedules from Revit.
I want to merge these schedules so that wherever there are identical parameters, they will appear in the same column.
I’ve extracted the schedule data using the Bimorph Schedule.GetData node, and now I’m trying to combine the lists in the proper way.
My biggest problem is that some schedules have unique parameters (for example, only one schedule uses Count, while another uses Length). I also have parameters that are used as product ID for each schedule.
The .dyn I’ve built does most of the work, but whenever a parameter is missing from any schedule, the values are placed incorrectly in the Excel.
I’m attaching the .dyn
Let me know what you think!
Schedule-Based-BOM.dyn (61.3 KB)
