mergePDF node is not working
Morning,
As a last resort, maybe it doesn’t work, but could u upload your script here? Then I can try that one. It is a straw but you never know.
Hi @d.jansenMM3LJ ,
Please find the graph.
(I tested the error you are experiencing with a dummy file so the part with the printsettings isn’t realistic)
0_Batch Print PDF and Merge.dyn (18.0 KB)
1_Batch Print PDF.dyn (15.2 KB)
2_Merge.dyn (11.1 KB)
Hi @Alban_de_Chasteigner,
And again no luck. I get the same error as expected. However your script gave me an idea, as long as I use the sheet numbers from the schedule node and put them in the desired folder with names that end with …Sheet 1, Sheet 2, etc. I can simply put them together with adobe pro and the order will not be random as it is now.
So I guess it is a little win there.
Thanks Again!
Just so to close this off.
After I plot the PDF files I use a script that renames the pdf files so I get the order of files I want and then combine them in Adobe Pro.
