Hi, I would like to merge base level and text in to new text parameter, i have got this list:
Level(Name=L 1, Elevation=3700), I just want to take L 1, is it possible?
Much appreciate for the help.
Intan
Intan
thank you for your help,
so the code block should be created one by one? L1, L2…Ln? or possible to using ignoring case for text not to be used?
I found this very helpful, thank you.
It works, thank You Vikram & Kulkul…
Kulkul, now i understand both of methods, thanks anyway…
Can you mark the post as solved. Thanks
