Hey there, i have these two lists. They are parameter from the same windows.
I want to make a little math. the math depends on the Orient parameter. So for example, all that have south west, gets * 0.8
How do map this in the most effecient way?
Put your 8 Orientation strings into a Dictionary with the corresponding calculation factors. Read the Area and orientation, ask Dictionary for the factor, multiply area.
Sounds good, i never used dictionary, can you show me how that goes?
https://dictionary.dynamobim.com/2/#/Dictionary
https://primer.dynamobim.org/09_Dictionaries/9-1_What-is-a-dictionary.html
Both links took me 10 seconds to find using Google.
Do some research and give it a try.
@Pedeh You can use dictionary as shown below
Or do something like this
Using a dictionary is more efficient and usually recommended.
However, using the 2nd method should almost be equally efficient if you have a smaller set of elements.
And if you just need to define the factor for 1 direction, use the if condition like this
Thx for making me aware
This was a quick and awesome way to learn, the Dictionary part, more than the primer has to offer Thx a ton.
