Is there any method to perform Math Ceiling to a float number and it should return a float to a specified number. The default node for ceiling in dynamo gives output as an integer.
Example: If I have a value of 1.36, then it should return a value of 1.50 with 0.25 specified value. And If it’s 1.23, then it should return 1.00
The default node will return 2 int in both the cases.
