I have a flattened list with sheet names taken from my DRAWING INDEX schedule. The ViewSets.ByViewsName gives null. I assume I need to convert the list to a VAR or Element. (Springs node is VAR, or if I use the node made by archilab, that uses element)
How do I convert the list from string to VAR or Element?
Thanks for your help!
This setup did work in the past. I had posted this about 4 years ago showing a working setup:
Not sure why this doesn’t work now,
Here’s the DYN file if you want to see it.
Thanks again for your help!
View Set from Drawing Index 3.dyn (32.0 KB)
