i have created python script, for that input is list of connector of a drawpit. drawpit have connectors on all four side and their descriptions are given as North, South, East and West for each side. this python script separates connectors by the side description and sort them base on id.
it is working fine if input is connectors of single drawpit. when input is multiple drawpit connectors. it is not working. please suggest what should i change to my script to work for multiple drawpit.
i also want to maintain list structure.
thanks in Advance.
python script is as below;
import sys
import math
clr.AddReference(‘RevitNodes’)
clr.AddReference(“RevitAPI”)
from Autodesk.Revit.DB import GeometryObject
from Autodesk.Revit.DB import Surface
from Autodesk.Revit.DB import Connector
from RevitServices import *
clr.AddReference(“DSCoreNodes”)
from DSCore import *
connectors = UnwrapElement(IN[0])
side = IN[1]
refvec = [0,0,1]
point =
des =
east =
west =
north =
south =
output =
def getConnDesc(connector):
desc = None
try:
desc = connector.Description
except:
pass
return desc
def count(List):
return List.Count
def n(Connector):
return Connector.Id
for i in connectors:
q = getConnDesc(i)
des.append(q)
a = 0
while a < count(des):
if des[a] == "East":
east.append(connectors[a])
a = a+1
if des[a] == "West":
west.append(connectors[a])
a = a+1
if des[a] == "North":
north.append(connectors[a])
a = a+1
south.append(connectors[a])
a = a+1
if side ==0:
origin = east[0]
sort = sorted(east, key=n)
output.append(sort)
if side ==1:
origin = north[0]
sort = sorted(north, key=n)
output.append(sort)
if side == 2:
origin = south[0]
sort = sorted(south, key=n)
output.append(sort)
origin = west[0]
sort = sorted(west, key=n)
output.append(sort)
OUT = output
