I know this question is not quite related to Dynamo perhaps, but I suppose Dynamo forum is more vocal than MEP forum, so I decide to put it here since didn’t get much attention back there.
It is really bothering.
Here’s my situation. Our team mainly uses data from CIBSE to calculate pressure drop for duct fittings. What Revit has are: built-in ASHRAE table, Specific Loss, Specific Coefficient and Not Defined. It pretty much leads me to Specific Loss / Coefficient. So I thought about maybe I can map data from CIBSE to the fittings onto these two options via Dynamo or some API calls later. But I found that some of the fittings does not even have these options under loss method. At first, I thought I was just dealing with few bugsy duct fitting families. But it turns out Revit Sample project has it too, some of them have just only ASHRAE and Not Defined.
I found some discussion saying this issue exists in previous versions. Some found Revit wiped out these two options in Revit 2017. I cant say much about Revit 2017 but I’m experiencing it in Revit 2019.
@Mark.Ackerley Thx! Very informative link, I could use it later.
After days of collecting info and testing, I found out that Revit had removed Specific Loss & Specific Coefficient for fittings with more than 2 connectors since 2017. But I dont think that is what they real mean by concluding to “more than 2 connectors.” Because in fact, my tap here only has two connectors. So I guess it becomes more like if a fitting is going to cause pressure drop at multiple spots (e.g. on main duct and branch duct), Revit won’t offer these two options because the specific loss/coefficient user gives won’t be applied to the spots in a way that user is expecting. So user has to rely on ASHRAE table then.
Well I definitely spoke a little too soon. I was able to force any fitting to the specific coefficient option but then it would not display the button to input the actual coefficient
I am actually looking for a way to set all 2800 of my users elements to a loss method that would remove all the warnings from their model. Not being an MEP Engineer (Architectural Background here) is it possible to do so? Our Engineers do not use Revits system for any of this so I want to try to turn it “off” so that the 2,800 warnings get cleared. Has anyone figured out how to do this? IS it even possible?
