<p class=“p1”>Hello,
I’ve got my own function, that you can see working in the block below. But I can’t get in going within a loop. Are you able to see my error? And could explain the [Imperitave] command?</p>
<p class=“p2”>
</p>
<p class=“p2”>Thanks a ton,
Steve</p>
Hi Steve,
I think you’ll need to define “func” inside the imperative section( inside the {…} ). Right now you’ve only defined it outside.
Hi Steve, it is a bug – imperative language block doesn’t pass a correct func to __Apply() funciton. We’re fixing it.
Hi Yu Ke,
__Apply() seems to be working with the daily versions:
Thanks for the input.
Best,
Steve
