Using Dynaworks I have created a work space that does the following:
Open Navisworks file.
Gets Selection Sets
Converts selection sets to element IDs
Applys selection set name to a parameter in Revit for those elements.
It works great with one selection set. When I introduce a second set it changes things.
Essentially, what I am trying to do is run the tasks first for “Test Selection 1” then for “Test Selection 2”… and so on… Logically it sounds like a loop but I am not quite wrapping my brain around how to attack it. If you see in the example I used a GetItemAtIndex to only perform the task for “List Selection 1”… I want that to loop and then perform the tasks for “Test Selection 2”…
I have reworked it a little… It might help explain what I am trying to do…
Basically, the code block that is hooked up to the “list.GetItemAtIndex” represents the number selection sets. By flipping though each number “0,1,2” and running Dynamo I am able to apply the correct parameters to the correct elements… I want to automate running through index 0, 1, 2, 3… etc… Not sure if that helps make more sense of it.
