Hi everyone. I have a lot of small prefabricated slabs. The gap between these slabs are around 2-4 cm. Currently i place the filled region on the slabs gaps manually. I have 2 types of filled region. one to place on the longer side of the slab and other type on the short side of the slab.
I am looking for possible idea how can i get this done with dynamo? Currently i got the top surfaces of all the slabs but not sure how to move forward with the problem.
Hi @ammad.mahmoodQ4GLD sure its possible, but not so easy as it sounds, you will need pair all boundery curves up and then create the filledregion…could you show you graph so far??
and PS guess you will not even need the centerlines in that case here , only pair these curves up and do a loft with these curves,and get perimeter curves from that and should have the boundery for create a filled region …maybe
no and will not help as my nodes has a lot of dependencies but only to my own nodes, so it will not be a single node ever…its build on my nodes, basic a big system…good or bad, but thats how it works in the moment maybe i will publish it in the future…but not right now…as i just still playing around and basic love it that way…hahahaha
My experience with precast is to model it in Revit. Use reference lines and align and pin a cutting void family with the ability to adjust the ends. I guess this depends on the LOD
