I Have to send to excel two lists
First list on column A, and second list on column B
Here, i join the two separate lists, and i use “Chop” node to cut the result, and have a two columns list
in my dyn file, i find solution, but i introduce manualy sub length value
it will be hard to do if i have 15-20 columns to create on excel, i suppose i’ll use for each cut the “chop.list” command
It’s impossible to link each list directly to “Data” input of “Write Excel” node, because for each list, excel create a new sheet, and overwrite old data
Thank you in advance
