I have my XY Frame Extents node capturing the extents of a series of model lines (a la site) in Revit. I’m then intersecting a grid-like series of lines from this Frame with a surface created by the selected model lines before intersecting the perimeter curves of said surface.
This gives me two lists. List1 = Perimeter curves that runs clockwise. List2 = Grid-like intersection that runs horizontally.
They don’t marry up.
Any thoughts on the best way to approach this?
I tried re-projecting the points to the surface to try and automatically relist them to no avail. I also mucked about with Sort by Key and Point.X/Point.Y
Thoughts ?
Didn’t understand as to what exactly your problem is.
However, two lines in your code caught my attention.
int0 = lst0.Intersect(bel0<1><2>);
int1 = l0.Intersect(l1<1><2>);
Not sure as to whether having the replication guides at those positions help give you the intended results.
I haven’t tried running your code, but for variations I might suggest…
int0 = lst0<1>.Intersect(bel0<2>);
int1 = l0<1>.Intersect(l1<2>);
or
int0 = lst0<2>.Intersect(bel0)<1>;
int1 = l0<1>.Intersect(l1)<2>;
Also, try swapping 1 and 2
Sorry, I haven’t yet managed to properly understand replication guides to provide a better response
Hello Vikram,
Yeah I know my code is a little inefficient - I’m just playing until I get it working before refining
Still need to figure out the above mentioned issue. It’s a case of wanting every single point (Both rim and internal) to be in the same list, and in a logical order.
Bit stumped.
Ok I figured out an alternative solution
I re-wrote my inputs - and have created a custom node out of it. I’ll publish it sometime soon.
Sol - Here is my solution at your problem
File: Point Sequence
Awesome Vikram. I’ll have a look at that in depth later
