List.RemoveIfNot gives me unexpected results in Civil 3D 2021. It recognizes Polylines and Blocks but not Circles and Lines. Is it a bug?**
@clas.kristiansen if you over the mouse on the type input port you will see the hint for the expected type, which is a string and not an Object Type.
The dropdown nodes resulting data type is a string if I am not mistaken.
I believe that the issue is that the Dynamo for Civil team passes “Line” as the result so Dynamo is looking for a Dynamo line rather than a Civil3D Line Object, and therefore the work-around is required.
Thanks you lead me on the right path!
Autodesk.AutoCAD.DynamoNodes.Polyline and Autodesk.AutoCAD.DynamoNodes.Circle … and so on does it.
