List of intersecting elements
Hey, i’m new to dynamo.
So i’m trying to make Dynamo report on which room is intersecting with which Radiator (mechanical equipment).
So i made this dummy model for testing, 4 spaces each with their own rad.
In the blue, you can see that it works just fine when i select one at a time, but i want to do all at once as you can see, I’ve tried several methods of doing this, but all report all false.
What am i missing?
try this
Thanks for replying! Unfortunately its still showing false:
intersect%20try%20this
there is a node in BimorphNodes package called IntersectsElements
try it
There is a node in Archilab called point.room or Room.AtPoint which might simplify this exercise.
Hi everyone,
I am trying to select all generic models (Builders work openings) that intersect with pipes or Ducts or Cable trays so that i can add a description of what is going through each opening.
As i have over 1000 openings, i am looking to automate this process. I think the back half of this will work i just need some help with the output. Ideally, it will select all the generic models in the revit view that are intersecting with the chosen category (pipe, duct, tray).
Any suggestions welcome! thank you.
Bro just give up it’s impossible
Thanks Tomas,
Can anyone help me prove him wrong??
It’s possible, but this is quite off topic. Best to start a new thread and include a sample RVT and your current DYN.
