Hi
If I have a simple list of lists, what is the best way to check if the lists are continuous? For example, in the image below, List [0] is not continuous, whereas list [1] is. Is this a task for Python or can it be achieved with OOTB nodes?
Off the top of my head, try this:
(List.Drop(lst,1)-List.Drop(lst,-1)) ==1;
Then check if all true.
Python definition
def sequential(list):
check = []
for i in list:
try:
if list[list.index(i)+1]==i+1:
check.append(True)
check.append(False)
except:
pass
return all(check)
input = IN[0]
output = []
for i in input:
output.append(sequential(i))
OUT = output
Hi @Paul_Wintour ,
Just another perspective to your question. Have you considered forward sequence only? How about the reverse? say 3,2,1 is that considered as continuous as well?
I believe python by @Ewan_Opie would be the cleanest. But if purely nodes and simple code blocks then check out this option.
Sample Dyn - ListContinuousForwardBackward.dyn (39.9 KB)
Cheers,
Jowenn
@simoneavellini This is what I was after. Thanks.
Thanks too for the Python script @Ewan_Opie. Lots of options
@JowennLua Forward sequence only as they were indexs of elements.
Hello
you can also use the range function Python to compare
myList = IN[0]
OUT = (myList == list(range(myList[0], myList[-1]+1)))
