I don’t understand why I’m getting -1 as indices. The only one correct index is the number 2 at index 4.
Can somebody explain that and how to get the correct indices, please?
My guess is that it is a rounding issue. Try converting to a string first. It also may be that using a dictionary would be better suited for what you are after.
Thanks for the reply Jacob.
Based on what you suggest, I created a list manually and it worked just fine. Then, I tried Number.ToString from Springs nodes but it didn’t work (see image). Do you know what node I can use to achieve that?
